running like crap
Old Nov 16, 2005 | 09:26 PM
darrell hoagland's Avatar
Question running like crap
just put a new fuel pump in and it holds 42# idling put a new optie in it last year.when i drve it it runs good for a little bit but when i take it up high it starts to spit and spuder. tried to drive it to work today and it didnt make it when i was going down the parkway it would spit and spuder and die but it would crank back up but i dint make it far any thoughts thanks
Old Nov 16, 2005 | 09:58 PM
Formula WS6's Avatar
stupid question, did you change the fuel filter?
Old Nov 16, 2005 | 10:23 PM
yes i did when it starts acting up the fuel pressure stays the same i thought it was the pump again
Old Nov 17, 2005 | 03:39 PM
Cheater's Avatar
Maybe opti-spark or spark plug wire on headers
Old Nov 17, 2005 | 03:48 PM
blkchevyz's Avatar
check your coil wire
Old Nov 20, 2005 | 09:40 AM
Put A New Coil And Coil Wire On No Difference Could It Be My Pcm just put my stock mass air back on didnt change a thing some one help
Old Nov 20, 2005 | 11:15 PM
t t t
Old Nov 21, 2005 | 10:24 AM
dhdenney's Avatar
Well one time I had a similar problem but I knew it wasn't the opti. I thought I had bad gas so I got some better gas, changed the fuel filter and nothing changed. Turns out I had a couple dead plugs and presto! Problem solved.
Old Nov 21, 2005 | 04:40 PM
infinitebird's Avatar
Yeah try plugs/wires first if you haven't. That fixes a lot of problems. If it's a high mileage car with the stock opti then maybe look at that next.
Old Nov 21, 2005 | 09:44 PM
dealer ship tuned it up and put a new optie in it last year maybe its going out again
Old Nov 21, 2005 | 10:03 PM
dhdenney's Avatar
Scan it for codes. Mine showed up with a "lo res failure" DTC.
Old Nov 21, 2005 | 10:18 PM
garth285's Avatar
how old r ur injectors, mabey they need to be cleaned, I cleaned my 146,000 mile injectors and it cleane dit up a WHOLE LOT!!! jsut my 2 cents
Old Nov 21, 2005 | 10:50 PM
Put Some 24#injecters In It. Ran The Codes It Pulled Up 8 Cant Remember All But Egr Lean On Exceleration .got It Out Of The Garage The Other Day Service Engine Light Wasnt On I Drove It About 3 Miles It Started Acting Up When It Starts Acting Up Its Like I Shout The Key Off But It Will Start Right Back.I WILL RUN THEM AGAIN TOMORROW
Old Nov 21, 2005 | 11:30 PM
8 codes? I'd say you've got major issues if that's the case.
Old Nov 26, 2005 | 01:09 PM
got the car out of the garage today check engine light wasnt on but after i drive it for about 20 or 30 and it warmed up real good it comes on and starts acting funny could it be my optie
