Where do I get a AIR SENSOR relocator?
Old Nov 22, 2005 | 07:03 AM
Clean94Z's Avatar
Default Where do I get a AIR SENSOR relocator?
Can't find them anywhere.
Old Nov 22, 2005 | 09:48 AM
Chris 96 WS6's Avatar
Not exactly sure what's you're wanting. All you need to do is create a new hole for the sensor then extend the wiring. I've not seen a "relocator" kit for this before.
Old Nov 22, 2005 | 09:53 AM
SmokedOutZ28's Avatar
https://www.casperselectronics.com/M...ry_Code=camaro
Scroll down to the middle of the page, they have 36'', 24'' and 12''
Old Nov 22, 2005 | 10:16 AM
MattZ28's Avatar
Pointless mod bro..
Old Nov 22, 2005 | 10:46 AM
Originally Posted by MattZ28
Pointless mod bro..
And your reasoning behind this?
Old Nov 22, 2005 | 05:37 PM
Clean94Z's Avatar
Why is it pointless? Just curious?
Old Nov 22, 2005 | 07:44 PM
buffman's Avatar
Because the PCM will eventually "figure out" that the air you're drawing in is not as cold as that IAT says it is. Maybe worth doing it for a couple passes, but the PCM is eventually going to know what's going on and it's going to adjust for it to negate any gains you might have had.
Matt
Old Nov 22, 2005 | 08:22 PM
Matt
he's talking about relocating it away from the hot engine... Not telling the computer that it's 0 degrees outside when it's really not.. i personally believe that it's worth the 40 bucks spent. My IAT would read 110 degrees when the outside temp would be 70-80 degrees I see no harm in telling the computer what the actual temp of the air that is comming into my engine rather then it seeing false under hood temps.
Old Nov 22, 2005 | 11:53 PM
buffman's Avatar
good point I guess that one went over my head. I myself am thinking of relocating mine seeing how mine is also 40-50 degrees over ambient temps. Now to just find a place to put it.
Matt
Old Nov 23, 2005 | 10:25 AM
blkchevyz's Avatar
at wot?
mine would read higher at part throttle but once i hit wot it would basicly hit the outside temp...
Old Nov 23, 2005 | 08:23 PM
Cheater's Avatar
SLP, but i would not waste the cash.
Old Nov 23, 2005 | 08:42 PM
Originally Posted by blkchevyz
at wot?
during normal driving conditions.... How long would you have to be at WOT before the sensor reads the actual temp of the outside air???
Old Nov 25, 2005 | 09:15 AM
blkchevyz's Avatar
it was pretty much instint
Old Nov 25, 2005 | 05:47 PM
can't say that mine changes that way. did some data logging the other night and it took over 10 secs @ WOT for the sensor temp to change 5 degrees.
Old Nov 25, 2005 | 11:34 PM
buffman's Avatar
yeah. From loggin it takes a couple mins on the highway for the IAT on my car to get within 10 degrees of the ambient temp going 60mph.
Matt
Old Nov 26, 2005 | 03:24 AM
Compstall's Avatar
I used $0.10 worth of wire and splices.
Old Nov 27, 2005 | 10:50 AM
Bud M's Avatar
http://www.jegs.com/webapp/wcs/store...tegoryId=18141
