Help!@# Car Trouble!!!!
Old Nov 23, 2005 | 05:36 PM
Fade2blk500's Avatar
Default Help!@# Car Trouble!!!!
Okay so the car died about a month back and wouldn't crank back. I replaced the opti with a brand new one from jason cromer. I noticed that the opti harness was corroded, but didnt have the money at the time to replace it. Bolted in the new opti and everything.. car fired rightup. 3 days later it stalled out and wouldn't crank back. I figured it had to be that bad harness so i purchased a new harness from gm for 150 bucks. Car fired up perfect. Drove it 10 miles, car stalled out again and now continues not to crank back. I am lost as to what it could be.
Craig
Old Nov 23, 2005 | 05:39 PM
blkchevyz's Avatar
have you checked your fuel pressure?
Old Nov 23, 2005 | 05:57 PM
yes fuel pressure is good, i know for sure its not getting any spark. i pulled the #1 plug connected it to the plug wire and held it to a ground and know for sure its not getting any spark. i just have no idea why it wouldnt now..
Old Nov 23, 2005 | 06:00 PM
Dragframe's Avatar
ignition switch? it cranks but no spark right? ignition switch sounds about right. cuz in my s10 when the ignition switch went out, it was a intermitant (sorry for spelling) problem.
Old Nov 23, 2005 | 06:01 PM
blkchevyz's Avatar
might need to check the coil and ignition module
Old Nov 23, 2005 | 07:12 PM
Alright autozone has the ignition switch listed for 9.99, the ignition coil for 14.99 but the ignition control module is 65.00. looks like im about to make a trip and replace it all!!
Old Nov 23, 2005 | 10:06 PM
where is the switch located and whats the easiest way to install it??
Old Nov 23, 2005 | 11:08 PM
METALBEAST's Avatar
I had the same problem on the Vette a couple of years ago Craig. It ended up being a bad ignition module on mine.
