Couple of questions
Old Nov 28, 2005 | 04:49 PM
Klortho's Avatar
Default Couple of questions
1. I'm in the process of putting my LT1 back together, lined up the dots on the cam and crank gear on the timing chain, but the where the pin goes into the opti is marked "6" instead of the "1" spot. Is this correct? I know that the crank is on TDC because I have compression on #1.
2. Valve lash, I adjusted the valves like a normal SBC, took all lash out, then 3/4 turn more. Is this correct as well?
Thanks for any input.
Old Nov 28, 2005 | 04:58 PM
dhdenney's Avatar
Sounds good to me. Only way to know is try to fire her up. Do you have an unvented opti? The "slot" has to be at the 9:00 position and #1 at TDC. That was always how I timed mine.
Old Nov 30, 2005 | 12:56 PM
Klortho's Avatar
Ok cool, no it's a vented opti, motor is a '95 model. The slot is at the 9 o'clock position so sounds like I'm good to go.
Thanks
