bouncing off rev limiter
Old Nov 29, 2005 | 08:10 PM
road_rage187's Avatar
Default bouncing off rev limiter
ok, lately i have been noticing that, at about 30mph when i put the pedal to the floor, it wont shift, it just climb up the rpm gauge and then just sits there and bounces against the rev limiter, and i did this a few days ago and i thought it was just a fluke and i did it again today and it did it again, but when im driving fine, it shifts good, whats wrong with it
Old Nov 29, 2005 | 09:07 PM
1SLO6's Avatar
its sounds like u have an automatic and it may be your tranny starting to slip..... just my opinion thou
Old Nov 29, 2005 | 09:19 PM
State69champ's Avatar
mine does the same shifting out of second when i ahve the car in D i just had my tranny rebuild... i dont belive its slipping. A tune will help im sure
Old Nov 29, 2005 | 09:46 PM
Chopstix's Avatar
check your fluid level.
Old Nov 29, 2005 | 10:12 PM
Dragframe's Avatar
ditto... if your fluid is even half quart low it will bounce off the limiter before shifting
Old Nov 29, 2005 | 11:45 PM
RoAdRaGe912's Avatar
nice name
do you know what gear it's in when it hits the limiter? if not then what speed is the car at when it bounces off of it?
i know you said when u punch it around 30, but i wasn't clear on if it did it immediately or took a while. to me it seems like u were in the bottom of second and it hit the limiter before going into 3rd gear but i wasn't to be sure.
Old Nov 29, 2005 | 11:58 PM
Speed Density's Avatar
hashtagBMW
MY car did that for a few days, then it went away.
Old Nov 30, 2005 | 06:24 PM
hey, yea i put 2 quarts of fluid in it, and it i havent tried punching it again, cause then i had to go to worl, but i think that was the problem
