Cam Swap plans Complete
Comp 26918 Beehive springs
Comp spring locators
Comp 11/32 10* lock set
Comp Titanium Retainers
Comp 1.6 NSA rockers 7/16"
Comp 7/16" rocker arm studs
GM guideplates
Comp Chromemoly Pushrods
Comp Timing Set
Comp "R" Series Lifters
Camshaft Gasket Kit
Pcmforless.com Tune
This is lookin like what my setup will be. At least pretty damn close, im not possitve on the lifters or the timming set but i think everything else is good.
If you guys got any suggestions let me know. Im up for change.
he is right about the lifters, cz28 has a sticky about them in the lt1-lt4 section. stock replacements are what everyone is recomending instead.
another thing you might want to consider is your cam bearings, if they are going, probably are with 130,000+ miles on your car, you will need to have them replaced, (I know you are proud of your service record, but I have seen the condition of your plugs, so who know what the last owner did) which might run you deeper into the money pit called power you are now addicted to.
