timing chain question
Old Dec 3, 2005 | 09:48 AM
dsmawd350's Avatar
Default timing chain question
Simple question here. Im swapping to a cc306 soon what are my options for a timing chain since my car is a 93 with the non-vented opti? I already have an elec. WP but i dont wanna switch optis.
Old Dec 3, 2005 | 10:27 AM
brandboZ28's Avatar
Pretty much either a Lunati or a stock set. Its been said that the Lunati timing set is just a stock set with a $100 mark up but I dont have any personal experience with it. Im using a new stock chain on my car with the GM847 without any problems.
Old Dec 3, 2005 | 12:41 PM
Admiral94's Avatar
The Opti has nothing to do with the timing chain. Since you are already using an electric water pump you can use a Cloyes double roller chain. Probably runs in the $70-80 range.
Old Dec 3, 2005 | 04:09 PM
dsmawd350's Avatar
^^ research before you give wrong info. you have to switch to the vented 95+ opti to run alot of the timing chains bacauae of i think a keyway on the opti drive
Old Dec 3, 2005 | 07:35 PM
dhdenney's Avatar
I am using stock replacement chain. I think any other chain is just a waste of money.
Old Dec 4, 2005 | 12:04 AM
busta9876's Avatar
93 modle the Opti is splined to the camshaft spocket. is 94 also?? i cant remember, but later years used the Pin drive optispark, requiring a longer the usual pin on the camshaft.
running any cam designed for later LT1 will require dowell pin pushed in to normal length of SBC, or cut to correct length.
If it were me i wouldnt go to trouble of buying expensive timing chain for 93 modle, but upgrade to vented opti, later timing cover, etc.
Old Dec 4, 2005 | 04:50 PM
dsmawd350's Avatar
so i finnaly came up with a conclusive reply on another board "there is no way to run any true double roller/or Hd timing chain with a 93-94 cover/opti. You must upgrade to a 95+ style cover, opti, and WP. " looks like ill be going with a brand new stocker.... ive heard of quite a few people running them with no problems
Old Dec 4, 2005 | 07:55 PM
dhdenney's Avatar
I wouldn't think twice about it.
Old Dec 4, 2005 | 09:24 PM
97LT1's Avatar
Yeah I would say IF you have to change your opti in the future to just go with the newer timing cover and opti. That way if you ever have to put a new chain on you will have more options.
I just put a new stock one back on when i swapped cams.
Old Dec 4, 2005 | 10:00 PM
dsmawd350's Avatar
yeah i just put a brand new GM opti on less than a year ago so i dont wanna switch now. stocker it is.
Old Dec 5, 2005 | 12:37 PM
dsmawd350's Avatar
where is the cheapest place to pick up a stock replacment
