Ignition experts help an LT1 guy out.
Old Dec 5, 2005 | 08:50 PM
A-man930's Avatar
Default Ignition experts help an LT1 guy out.
Ok, I don't know how many LT1 guys are in here but I figured this would be a good place to ask. As I discovered today, MSD is offering a complete Opti-Spark replacement with all kinds of fancy improvements. Before I had heard this, I was considering a Delteq Opti-Direct system, which uses brand new coilpacks designed for the V8s in Auroras (and Northstars as well if I remember correctly) instead of the single-coil system in the stock Opti system. The optical sensing unit of the stock distributer is still used, but high-voltage is no longer in the Opti to cause internal cap & rotor wear, internal arc over, and cross firing trouble. The supposed advantage of the multi-coil setup is the longer charging time for a more powerfull spark. There are several companies that manufacture an "improved" opti, now MSD as well, so I'm wondering, is there really any advantage to the multi-coil setup? Because honestly the MSD is more attractive to me due to an easier installation. Any help is appreciated. Thanks!
Old Dec 5, 2005 | 09:07 PM
hondo's Avatar
you might wanna check this out tooo
full throttle ls1 coil kit
ive never used one,but it's similar to the delteq just uses ls1 coils plus it has some other cool stuff like a two step and nitrous retard etc built in
Old Dec 5, 2005 | 09:17 PM
MAC4264's Avatar
The only advantage is the one your stating about crossfire trouble and cracked caps etc., no more opti troubles. Other than that,the coil packs are just a trick of the week part that look cool and cost money (the LS1 has them so I need them). The MSD stuff in the past has been very good stuff some I'm sure you would not be disappointed in the product. The truth is if you don't have a major ignition problem there is no real gain in new ignition like some manufactures claim.
Old Dec 6, 2005 | 01:48 PM
A-man930's Avatar
Thanks guys. That'll help!
Old Dec 8, 2005 | 09:34 AM
slowpoke96z28's Avatar
http://www.dynotech-eng.com/dynaspark.htm
this is an interesting piece as well. everybody I have met that has one says it is worth it.
