Brake Abs Bypass
Brake Abs Bypass
My Abs Module Is Strippied Out So Instead Of Fixing That I Was Wondering If I Could Just Bypass The Thing And Hard Line The Front And Rear Brakes But There Are Only Two Lines Coming Out Of The Master Cylinder Should I T One Of The Lines And Run One Of Them To The Front And Split One To The Rear But Was Wondering If That Would Make The Car Pull To One Side... Or Do One Of The Older Non Abs F-bodies Have A Three Line Master Cylinder Or What Are My Other Options?
You should check the sponser SJM Man. => http://www.sjmmanufacturing.com/cam_brk_lt1.html
The sell kits to delete the ABS. Comes with prebent lines, proportioning valve, and necessary fittings. You can also get a kit that includes a line lock. I will be getting one this winter. They are very nice kits. Everything in one nice package.
i will sell you my module so you can fix your abs if you would like 50 bucks and it yours email me since i hardly am able to get on here Hottstuff45623@aol.com
