Need help picking a block. . .
Old Dec 13, 2005 | 11:38 AM
96 LT-1's Avatar
Bad Seller Warning!
Default Need help picking a block. . .
Well my project is going to take place this winter.... And im getting a new block , stroker kit , & H/C package from port pros. But i need advice on picking the right options.
First decision to make is 383 or 396 ?
Im thinking im gonna go with the 383 because ive heard the 396's are kinda weak and id like to run a fairly big direct port shot... and a big cam.
But the second decision I have to make is short or long block?
This one ive tried searching on tried reading on and cant find much info on the differences? Is it still a direct swap? This is the one i really need help with thanksin advance guys.
Old Dec 13, 2005 | 12:21 PM
Desert Dog's Avatar
Short block:
block
crankshaft and bearings
connecting rods and bearings
pistons
rings
cam bearings
camshaft
timing gears and chain
oil pan
Long block
add these to the short block list:
heads
valves
springs
pushrods
lifters
oil pump
sometimes the water pump
sometimes the distributor
sometime the intake
So, if you have a set of heads ready to go, go short block....
Mike
Old Dec 13, 2005 | 12:30 PM
treyZ28's Avatar
regular tech
Old Dec 13, 2005 | 12:31 PM
96 LT-1's Avatar
Bad Seller Warning!
so there are no physical differences? its just what the block comes with...
Old Dec 13, 2005 | 12:44 PM
treyZ28's Avatar
a short block and a long block aren't dimensions.
long block vs short block is like "wheel and tire package" vs "wheels"
Old Dec 13, 2005 | 12:45 PM
Desert Dog's Avatar
regular tech
That is where I would move it to if I was a mod here... But hey, we have flappin' lips on this board...
YES
Old Dec 13, 2005 | 01:07 PM
96 LT-1's Avatar
Bad Seller Warning!
thanks i got it now =P
