LT1 guys lookng for another urbo alternative??
I am trying to gauge how much interest there would be for another LT1 turbo kit. Right now there is the Tti kit (limited to 550-600rwhp max), STS kit (good rear mount kit), and PTK kit (the best on the market right now...but $$) I would like to offer a log manifold system capable of 700rwhp. It wont have one side fed thru the the other log (like the TTi kit). I figure I might as well make a kit that will bolt in easy and support 700rwhp depending on the turbo, that way guys with stock bottom ends have room to grow if they want to build the motor to handle it. Here are the two kits I am debating about making:
Stage 1 Turbo kit :
Master Power T70
Tial 38mm Wastegate
Two 2.5" log manifolds with 1.75" primaries
2.5" cross over pipe with flex section
v-band clamps
2 O2 sensor bungs before the turbo, and one on the downpipe for Wide Band sensors (which you can plug if you dont want a WB)
You can fab up your on cold side (with or without intercooler), run an oil line to the turbo and drain back to the pan. You'l be ready to go.
Stage 2 Turbo Kit:
Master Power T70
Tial 38mm Wastegate
v-band clamps
Cold side aluminum piping from turbo to MAF
Tial 50mm Blow Off Valve
Silicone Coupler
Airfilter
Oil lines/fittings
Cold air side wont be for use with intercooler, but you can run an alky system if you choose. It will just go from turbo to your MAF.
I prefer people to email me with questions/concerns/suggestions. I am not a sponsor, so i will not answer questions about pricing at all on here. I just want to see if people are interested.
Shoot me an email for questions/comments..... jrbellas95z28@yahoo.com
Stage 1 Turbo kit :
Master Power T70
Tial 38mm Wastegate
v-band clamps
Stage 2 Turbo Kit:
Master Power T70
Tial 38mm Wastegate
v-band clamps
Silicone Coupler
Airfilter
Oil lines/fittings
Originally Posted by tekprodave
I'll be in the market for a turbo kit soon but I'm not fond of the log style manifolds.
Originally Posted by RealQuick
Any other interest? What would people be lookin for when buing a kit/ What king of price range would people wbe willing to spend? What hp goals, etc.
![Rock](https://ls1tech.com/forums/images/smilies2/rock.gif)
