Problems installing 58mm tb on 95 vette
I tried to find a site for that space and found nothing.
Can I guess that it is tapered to allow you to use a 58mm TB without grinding on the intake?
In which case the resolution is simple put the stock TB back on, it is not a restriction on a stockish motor.
I put a 58mm I got cheap on my cammed motor with higher flowing heads than yours the stock iron ones(yes that is correct) and I noticed no SOTP power gain or anything in datalogs that shows more air movement. IMO those who claim to see big power gains from TB swaps on stockish cars can not tell the difference between throttle response and power. They do change throttle response.
If you have an automatic car a larger TB can spell death to the tranny unless you reprogram for it or modify the tranny.
