Is there no aftermarket Intake for the LT1/4
I can't find anything except a carb convertion intake.
What are my options??? If any to stay EFI
1995 LT1/M6
1995 LT1/M6
nothing unless you wanna get a single plane carb intake conveted for injection and then get a 4 barrel throttle body. i believe someone converterd a stealth ram for an lt1 but no one ever tested it so that might not even be much better.
Originally Posted by whynot
edelbrock has one, no idea if it is any better than stock though.
They had one. I don't believe the LTx intake they designed was ever produced. If it was I recall it was shortly pulled because no gains were made with it over the stock LtX intake.
Matt
Lingenfelter adapted several TPI aftermarket intakes for use on the LT1 you are talking over $800 to make one work though and it not really being worth the gains.
On Gen1 motors the intakes were crap so intake upgrades were common and readily available, on gen 3s they went tuned intakes again to boost peak numbers at the expense of average this is why LSX motors can put down such massive peak numbers but then only do good not great at the strip so there are options ther as well.
For the LT1 they went untuned and really stumbled onto something all the math and theory says it should not work as well as it does on as broad a range of applications as it does. Not that it is perfect it just does a good job at everything it is asked too.
Also do not go thinking the LT1 and LT4 intakes are all that different from eachother, they are VERY similar neither being an upgrade over the other.
FWIW, the engineer who designed the LT1 motor Ron Speary wanted to do a longer runner intake like the LS1 but wasn't allowed to by his bosses. When I talked to him at PRI he really wanted to put more runner length on the intake, I guess the good thing that came out of not being able to do that is the LS1.
I've converted single planes, Stealth Rams etc... and they are all a better choice compared to a LT1 intake.
Bret
Bret
