Opti=$$$$
Old Dec 23, 2005 | 08:32 PM
Out1aw's Avatar
Originally Posted by dhdenney
Never buy an opti from any parts store. I personally have done this and they don't work right! Stick with brand new genuine GM optis or the aftermarkets (MSD and Dynaspark).
Ditto. Went thru 3 busted *** ones from Advance. Every time we took it apart there was something F(#&$)#Ed up.
Old Dec 24, 2005 | 04:11 PM
Black1997T/A's Avatar
Do Your self a favor and spend the extra buck and buy a brand new G.M. O.E. unit or MSD. Dont settle for anything less. Its not hard to replace, just time cunsuming. I could'nt agree more with outlaw 5.3
Old Dec 24, 2005 | 04:51 PM
redhot lt-1's Avatar
hey man i`m new and seen your post i recently replaced my opti with one from dynatech it was $615 but it supose to be the ****. made from billet aluminum it has 10 overall improvements from the stock unit. i personally have replaced my opti 5 times before i found this opti from dynatech.com it was desiged by racers to run cooler better crossflow ventilation to keep moisture out the list goes on call them at 1-260-407-5455 good luck e-mail me at iturner@sc.rr.com if you need more help
Old Dec 24, 2005 | 04:55 PM
monster7's Avatar
dynatech has some shady service, do a search on here about them
Old Dec 24, 2005 | 06:37 PM
buffman's Avatar
I think anymore after reading it's going to be down to a OEM GM unit or the new MSD after it get's a track record
Old Dec 24, 2005 | 06:50 PM
roughneck427's Avatar
Tell that dealer to **** up a rope
Old Dec 25, 2005 | 01:30 AM
NXSLT1's Avatar
I'd take the cap off and put loctite on the screws holding the rotor on no matter what kind or where you get it from.
Old Dec 25, 2005 | 01:35 AM
monster7's Avatar
yes best advice on the thread about that i have seen brand new ones loose as hell
Old Dec 25, 2005 | 07:24 PM
incorporeal's Avatar
Update:
Well it turns out that the cap is broken and causing cylinder #7 to misfire. Apparently the spark is being crossed between 1-5-7, so huge misfires. For now I was thinking on buying the MSD Distributor Cap and Rotor Kit. Yay or Nay?
Old Dec 26, 2005 | 05:14 PM
Default broken cap
well if that is the only thing wrong yea just replace the cap but make sure you clean it out and when putting it back together make sure the gasket is in place second for added protection run a thin layer of silicone a round the outside of the case were it come together after you get it together. i hope it works for you
