What does it take to hit 12's??
The 847 works great with the stock heads, sounds bad *** IMO. As soon as I get home I am going 2 stages progressive 1st stage dry, second wet, still on the stock bottom end. The ebay converter has worked great for me so far, I probably have over a 100 passes on it and no problems at all. Its just a restalled stocker but really improved the overall car, knocked .2 off the 60' as well.
I helped a friend go 12.98/105 (in 96 degree heat, mind you) a couple years ago, and all he had done was:
SLP cold air
BBK shorties/custom exhaust
Some sort of mail order tune
Sticky tires.
We put a gear in the car a few weeks later and ran it at our local 1/8th mile track, and it picked up .25 over 1/8th mile pass on the 12.98 run. Its relatively easy to run 12's, you dont need to jump straight to changing cam's and what not.
SLP cold air
Sticky tires.
Tom, is that your Cuda? Holy Crap that is one mean ****!
One of the best mods you can doto your car is a 2800-3000 stall and some sticky tires. That and the misc bolt-ons will net your some great 60ft times and some nice 12 second slips.
Mike
Mike
Took everything at my CarDomain site minus the blower. There are some really fast bolt on cars - I couldn't get my bolt on convertered car to do squat - like 13.40's - then a small cam and in the 12's.
Blower - 11's
Suspension/12bolt - ? this Winter's plans
Blower - 11's
Thanks Matrik, thats exactly what I was looking for. And what "free" mods did you do? And im assuming it was on street tires from reading your post on fastrides.com. Impressive, Thanks!!!
Originally Posted by matrik
My setup got me there, and I did it with shorties, hoping for better times with my long tubes and ory .
The shorty design seems to work very well in the LT1s.
SLP cold air
Sticky tires.
SLP cold air
Sticky tires.
To the original poster. It seems like you think it will be really hard to hit 12's and you will need nitrous. With LT headers, matching Y-pipe or some other catback, a CAI, a tune and a stall converter, you will be in the twelves. I would guess a 12.8-12.7 with a good 60' and if you have a healthy motor.
#32
#33
All bolt ons and some drivng OR drag radials. Get some drag radials and it will feel like a new car. I gained .5. Its nice to hit 2 gear and feel the car "hit" instead of slip.
Ryan
Ryan
#37
The 847 knocked off .2 on your 60 ft alone? How much in the 1/4?
#39
Moderator
Ryan
Ryan
Exactly, there is no reason at all in an auto LT1 you have to touch the motor to get 12s. A full bbolt on LT1 on drag radials should be in the mid high 12s.
