stock lifters
Old Dec 25, 2005 | 12:51 PM
Juicedz's Avatar
Default stock lifters
I have have dana lifters(hydrualic) which are basically just a stock replacement. How high of rpm can stock lifters or dana take before the power falls of dramatically? Also can one bad lifter or all of them cause such a dramatic power drop? The car is peaking around 6300 and was designed to peak around 6800 or so. The hp is dropping off by about 30 horse from 6300-6700. Also the tuning is the best it can get, a/f is 12.9 all through, andd spark advance pretty aggressive. We tried alot of things up top, but nothing helped. thanks guys
Old Dec 25, 2005 | 12:53 PM
The Big Show's Avatar
I wouldn't turn stockers more than 6500 tops before you can expect them to pump up and even thats pushing it. I use to think Comp R's were a cheaper solution but since the design change it appears the only real solution now is a quality lifter like Morel.
Old Dec 25, 2005 | 01:43 PM
Juicedz's Avatar
how much do the morels run for an lt1? Also do you think that is why my power drops off so quick?
Old Dec 25, 2005 | 02:01 PM
From what I have seen they run about 500 a set. LT1s and LS1s use the same lifter so if you see some for sale from a LS1 you can still roll with them.
Very well could be the cause of your issues but at the same time it could be something else.
Old Dec 25, 2005 | 02:02 PM
1BadAsZ's Avatar
most places are about $499 give or take. thunder has a valvetrain discount going on right now
Old Dec 25, 2005 | 03:45 PM
SStrokerAce's Avatar
Or a little cheaper.
The spring pressures on his setup are a little much.
Bret
Old Dec 25, 2005 | 04:16 PM
screamin94Z's Avatar
make sure your valvesprings are matched to the size of your cam and your rockers arent set too tight. that could kill your power up top.
Old Dec 25, 2005 | 05:36 PM
Yeah that's all taken care of, I've run these springs and lobes before and they work fine.
Bret
Old Dec 25, 2005 | 10:25 PM
Juicedz's Avatar
something else, what about my tranny? i went from a sixspeed putting 160 to the wheels on a 150 shot, then going to th400, 3800 stall and only put 130 to the wheels on a 200 shot, nothing else changed. Does the type of tranny you run (m6 or th400) depend on what rpm the power PEAKS at?
Old Dec 26, 2005 | 06:44 PM
If you look thru this site there is a guy who did a comparison of his 500+ rwhp LS1 setup with a M6 first then a TH400 and lost something like 100-150hp at the tires after the swap.
Bret
Old Dec 26, 2005 | 10:19 PM
Juicedz's Avatar
bret, you have an email @bauer racing
