who is running LE setup
Old Dec 27, 2005 | 12:27 PM
mike2244's Avatar
Default who is running LE setup
how many people are running lloyd elliots le1 package and what kind of numbers are you running at the track.
Old Dec 27, 2005 | 12:39 PM
T/ALT1's Avatar
I have been running Lloyds heads for a couple years. My first setup went from 12.00's@113mph with a custom cam and stock heades. I sent the heads to Lloyd and put them back on still stock valves in the heads and same cam. The car ran 11.66@117mph on it's first outing with the 3.42's and not dynotuned. Well I broke some main caps on the shortblock while spraying 150HP on it. So, I built a stronger bottomend with a CC306 cam and some bigger valves and went 11.20@120mph N/A and 10.17@134mph on a 200shot leaving easy. Now he just finished a set of fully ported Trickflows for me and the car is a beast even w/o any tuning yet. So you decide if his heads work or not. Later Clint
Old Dec 27, 2005 | 12:46 PM
mike2244's Avatar
i just got finshed installing the le1 and just wanted to see what it might be running in the 1/4 mile. i get my mail order tune today. i am scared to take it to the track with the 10 bolt in it, i don't think it will hold up, i was looking at putting a 12 bolt in it soon.
Old Dec 27, 2005 | 01:06 PM
T/ALT1's Avatar
If you are running an auto you will be fine on the 10bolt. The only thing is if you put lower than 3.42 gears b/c the gears are weaker. I was running the LE1 setup whe I ran 11.66@117mph. Later Clint
Old Dec 27, 2005 | 01:09 PM
mike2244's Avatar
i have the six speed and it has 3.73 gears
Old Dec 27, 2005 | 01:27 PM
T/ALT1's Avatar
Well you will be in need of a rear then. later
Old Dec 27, 2005 | 04:43 PM
roughneck427's Avatar
Hey T/ALT1 i have a 2 bolt bottom end and i was going to be spraying a 150 shot i have it studded did you actually break the cap or did it pull the bolts??
Old Dec 27, 2005 | 04:47 PM
T/ALT1's Avatar
The 2 bolts are usually pretty strong but anything can happen. Mine broke 3 main caps in half. I was running a cam with a tight LSA so that makes more cylinder pressure. You should be fine with the Hotcam or anything on a 112. Later
Old Dec 27, 2005 | 04:51 PM
Ahhh ok thanks yeah ive heard of people spraying the crap out of a stock bottom end like a 200 and be ok but like you said anything can happen
