What all would I need to buy to install a cc305???
Old Dec 27, 2005 | 11:07 PM
Chaotic Firebird's Avatar
Default What all would I need to buy to install a cc305???
What parts would I need to install a cc305 into my car? Like what lifters, roller rockers, springs, ect ect ect. I'm not that knowledgable when it comes to the drivetrain.
Old Dec 28, 2005 | 06:52 PM
99.9percenter's Avatar
Stock lifters are fine. You can use the stock rockers,but while your in there roller rockers would help.
Old Dec 29, 2005 | 09:43 AM
sssalah's Avatar
Valve springs are needed, crane has a nice kit 10308-1, comp 986 springs can be used also with the proper retainers and locators. Stock or stock replacement lifters can be used. 1.6 self aligning roller rockers from crane, comp or GM will work great.
Old Dec 29, 2005 | 07:08 PM
steez's Avatar
and retainers
Old Dec 30, 2005 | 07:44 PM
Thanks for the info. But I'm looking for more specific info. Like which exact parts from which manufacturer, stuff like that.
Old Dec 30, 2005 | 09:17 PM
Chris95Z's Avatar
http://compcams.com/Technical/Curren...ML/198-199.asp
there you can find supporting parts and numbers for the cam, as far as buying them a lot of the sponsors have specials from time to time to help save you money. It all depends on how in depth you want to go into the swap. Basically take your time and make sure you have everything. The simple version is to basically buy whats in the lt4 hotcam kit to get started. If you can it may not be a bad idea to upgrade to a HD timing set also. Search here and on camaroz28.com for the cam and whats needed. There's a lot of info out there you just have to dig and dig.
Old Jan 1, 2006 | 12:46 AM
Compstall's Avatar
Also budget about $100 for extras, i.e. gaskets, RTV's, oil, filter, coolant, etc.
