Lt4 dyno #'s
But back to the point, I'd like to see what other Lt4 cars are putting down. I have no intention of running NOS, so headers and a TC are about it for now.
Thanks guys!
i know that can be changed but take a look
really i dont think your going to seem too much of a change from stock lt1 heads and cam to lt4 head and an lt4 cam(not the hot cam)
those numbers dont seem bad at all for an auto with stock manafolds
Otherwise at worst someone took the intake and just had it powder coated red. If its running lean, get a tune
The thing is, he doesn't have headers. Personally that's what I'd expect a car with just the LT4 heads/cam and stock exhaust manifolds to put down.
Thanks,
Devon
From what you are describing of power through manifolds and being exessively lean I agree with those here who think it might actually be LT4 parts.
I also think you need to make sure it is programmed for such after you verify the head castings, that might be all it takes to correct the lean condition..
Thanks,
Devon
I understand that. It just sounds a bit fishy. There are some shady characters out there. But like I and others have said, the numbers do make it plausible. Check the heads and let us know
