comp beehive valve springs with this cam
Old Dec 28, 2005 | 12:50 PM
Formula69's Avatar
Default comp beehive valve springs with this cam
will those springs be ok with this cam? Custom Ground CompCam Cam duration @ .050: 224/236 Lift with 1.6 rockers: .536/.556 on a 114LSA + 4 degrees ground in.
Old Dec 28, 2005 | 12:54 PM
travie319's Avatar
they'll be great.....
Old Dec 28, 2005 | 01:12 PM
BlackScreaminMachine's Avatar
Internet Mechanic
If its the Beehives with the blue paint on them, they hold up to 0.600" lift, which yours is way under. Go for it! Just make sure your roller rockers are NSA (non self aligning) Unless I am mistaken and comp makes a beehive compatible with a SA rocker
Old Dec 28, 2005 | 01:18 PM
travie319's Avatar
part#26918.......
Old Dec 28, 2005 | 06:54 PM
monster7's Avatar
i have sa pro mag rockers with 918's so they work with sa rockers
