Lt4 compression ratio
Old Jan 2, 2006 | 03:03 PM
1uke's Avatar
Default Lt4 compression ratio
Building a 383 for a friend using Lt4 heads.
Using the supplied pistons his comp ratio figures to be 11.8-1.
cam is .540 236°@.050 .586 .238@.050 on a 112° L sep
How high can he feasably go on pump gas with reverse cooled heads.
thanks
Old Jan 2, 2006 | 03:08 PM
SStrokerAce's Avatar
That should be fine and not even pushing the limit.
You are in the wrong forum with this too.
Bret
Old Jan 2, 2006 | 04:13 PM
1uke's Avatar
thanx Brett,I tried to delete this thread and move it but had no luck.
