hp gain on lt1 with electronic water pump ?
Old 01-03-2006, 08:01 PM
Evilpontiac's Avatar
Default hp gain on lt1 with electronic water pump ?
I was considering getting a electric water pump for my 1997 trans am and I was wondering should I. It is a daily driver so I need it to be reliable. Should I get a electronic or should I stick with my stock? How much HP should I expect to get from an electronic water pump?
Old 01-03-2006, 08:04 PM
matt94z's Avatar
I've seen some dyno #'s posted somewhere, it was like 3-5 rwhp. I didn't tell much of a difference, but the car stays alot cooler.
Old 01-03-2006, 08:16 PM
Turbo_6's Avatar
Here, the dyno shows a 6.2 horsepower and 5.2 ft/lbs torque difference between the stock water pump and the Meziere electric pump installed. The average here gained 2.8 horsepower and 2.7 ft/lbs torque.
This pull was on a bolt on LT1 and the pull was to 5800rpm. Those that are spinning their cars higher will see even more gains.
Old 01-03-2006, 11:06 PM
TwoFast4Lv's Avatar
I showed 8RWHP on mine. then again I was spinning to 7,000 and making right at 400RWHP
Quick Reply: hp gain on lt1 with electronic water pump ?
