View Poll Results: GM847 or LT4 HotCam
GM847
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
126
78.26%
LT4 HotCam
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
35
21.74%
Voters: 161. You may not vote on this poll
GM847 vs LT4 HotCam
I am personally running the hotcam and its a great cam even if its old technology but I wish I would have went with a bigger cam and will go bigger in the future. The hotcam has great streetability and is a good sleeper grind. I say with a heavily modded car this is not the cam of choice and the GM847 should be chosen. IMO, the hotcam compared to the 847 is not comparing apples to oranges as previously mentioned.
Originally Posted by StealthFormula
GM847 is a beast compared to the LT4 hotcam
personally i think there both old, people are making way more power with similar sized custom cams.
Nothing wrong with a hotcam. I just don't want to have to put another cam in once I get bigger heads. I'm too lazy for that. I do lose a little gas mileage but if your worried about gas then you bought the wrong car
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by blkchevyz
the gm847 has been around just as long as the hot cam so the old technology is bs.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
When did he say that it wasn't? He never said that. He said he would have PREFERRED a bigger cam to the Hotcam.
#33
Custom cams are not that expensive, generally only ~$100 more to get the right one, the 1st time. Works out cheaper than most that go through at least two before they're happy
#34
Were can i get a Gm847 cam and wat else should i get for a stock lt1 with slp loudmouth cat back, spec stage 2 clutch and 4.10 gears? ( not looking ot spend the money for heads so u know the needed stuff ) thanx
#35
#36
#37
I would never ever buy a cam and then hae my heads ported, I would have my heads done and then have a custom made cam to go with my setup. Get everything you can outta it thats my thinking.
#39
My car is a daily driver, and I after put on some headers, I'll probably get an LT4 Hotcam and 1.6 RR's. What else should I add to complement the cam and roller rockers? - springs? This would be a good cam for someone like me, as I want my car to maintain driveability yet make some decent numbers.
