Many LT1 Hypertech Power Programmers in stock $275.00 ea
Old Jan 8, 2006 | 08:29 AM
EPP's Avatar
EPP
Smile Many LT1 Hypertech Power Programmers in stock $275.00 ea
We have quite a few Hypertech Power Programmers for LT1's in stock, that I need to sell. Hypertech recently changed from having a power programmer for every available year, to having a power programmer work for several different years. I have the ones in stock that are year specific, which is the only difference between the old ones and the new ones. Hypertech won't take them back, my loss is your gain. Call us for this special price. Bob
Increasing horsepower and torque is as simple as pushing a button with Hypertech's Power Programmer III! Simply plug the Power Programmer into the underdash diagnostic plug, answer a series of "Yes/No" questions, and the Power Programmer does the rest. The Power Programmer is much more than a tuning chip. It is a self-contained automotive tuning computer!
When you connect the Power Programmer to your vehicle, its "smart" program instantly recognizes your vehicle's powertrain by reading the Vehicle Identification Number (VIN). The VIN contains specific information on the engine, transmission, and drivetrain, which the Power Programmer decodes before it downloads the Power Tuning program that is precisely tailored to your car or truck.
The Power Programmer lets you choose Hypertech's Power Tuning program for regular 87 octane or premium 93 octane gasoline. Both options improve performance without detonation. After the tuning program is selected, the Programmer automatically installs the program and allows you to access and reprogram the vehicle's computer to function properly with aftermarket components such as non-stock tire sizes and rear-end gear ratios.
The Power Programmer is incredibly powerful, but it is also incredibly easy to use. Reprogramming does not require any tools or knowledge of cars or even computers. Plus, you can return to OEM (stock) programming in just minutes.
FEATURES
(depending on year, make and model)
Hypertech Power Tuning
Tunes the engine for maximum power and performance, plus potential gas mileage improvements
Three-Stage Power Tuning
Special Three-Stage Tuning for Select Vehicles
Dual Fuel Tuning
Lets you choose optimized tuning for 87 octane or 93 octane fuel
Engine Rev Limiter
Extends the engine's RPM range for a wider power band
Cooling Fan On/Off Temperatures
Permits use of low-temperature thermostat for cooler, denser intake charge and lower engine operating temperature
Transmission Shift Points
Optimizes shift points by speed and RPM for maximum acceleration
Transmission Shift Firmness
Firmer full-throttle gear changes for faster acceleration
Top-Speed Limiter
Allows the vehicle's top speed to be matched to the speed rating of factory-approved high-performance tires
Speedometer/Odometer Correction
Automatically corrects speedometer and odometer readings for non-stock tire sizes and/or non-stock rear-end gear ratios (accurate odometer readings are required by law)
