how much horse power can i expect
Old Jan 10, 2006 | 09:24 PM
road_rage187's Avatar
Default how much horse power can i expect
hey, i was wondering how much horsepower, i can expect out of this setup
1. MID-LENGHT HEADERS
2. 3'' CATBACK WITH BORLA CROSSFLOW MUFFLER WITH STAINLESS BORLA TIPS. NOTE THIS IS NOT A BORLA ADJUSTABLE CATBACK.
3. 3'' ALUMINUM LS1 DRIVESHAFT
4. NEW OPTISPARK (AC DELCO)
5. NGK PLUGS (NITROUS PLUGS)
6. MSD WIRES
7. MSD COIL
8. TB AIR FOIL
9. 1LE INTAKE ELBOW
10.GRANATELLI MASS AIR SENSOR
11.MOROSO COLD AIR INTAKE SYSTEM
12.RICHMOND 3.73 GEARS WITH MASTER INSTALL KIT
13.PRECISION INDUSTRIES VIGILANTE 2,800 STALL CONVERTER
14.B&M TRANS COOLER
15.NOS BRAND (BLUE BOTTLE) DRY SYSTEM NITROUS KIT WITH REMOTE BOTTLE OPENER, BOTTLE WARMER, AND PURGE KIT 100 shot
16.ALSO HAS A ALUMINUM HAWK CRANK PULLEY
Old Jan 10, 2006 | 09:32 PM
00transamnh's Avatar
uh .....car model?
Old Jan 11, 2006 | 12:20 AM
Formula69's Avatar
im guessing a 94-97 lt1 f body with high miles and an automatic transmission.. save your money on the driveshaft because 9 out of 10 of them arent ballanced for your can and will make your whole car shake after 70 mph... save your money on the air foil because it wont do much.. same with the MAF sensor.. aftermarket MAFs make it more difficult for a professional tuner (or any tuning in geneal) to tune your air fuel tables.the stock ones flow and work well enough to support somewhere around 500 hp.. what mods do you have to your car right now? as far as nitrous goes i wouldnt recommend it until you have a few more supporting mods. the combination between the lt1's infamous bottleneck heads and solid iron exhaust manifolds i doubt an lt1 could even flow enough gas and air to produce a true 100 whp shot.. you should get a set of longtube header to allow your car to breathe better.. because trust me thats what it needs
Old Jan 11, 2006 | 12:21 AM
Formula69's Avatar
oh and the underdrive pulleys are a good idea, but just remember.. the crank pully attaches over the existing stock harmonic balancer/crank hub, therefore adding weight to the rotational system and that is NEVER a good thing
Old Jan 11, 2006 | 09:19 AM
yea, this is on a 94 z28, that im thinking about buying, and it has 85,000 original miles
Old Jan 11, 2006 | 10:06 AM
METALBEAST's Avatar
I may have missed it but I did not see headers in your mod list. Those are a must if you are going to run nitrous.
