Tsp duals on LT1s
Since LT1 headers exit straight back, the TSP setup would take some serious modification to make work.
Look in Summit or Jegs, they've got generic TD setups that would likely suit you better.
It might probably be easyer to modify your set of headers to fit the TSP X. The big difference between most ls1 headers is that the driver side is angled toward the side of the car, and lt1 long tubes point straight back. It would be interesting to see if the collector was cut and a small angle welded in how close it would be to fitting that TSP X.
