Some updated pics of my project
Old Jan 15, 2006 | 06:30 PM
OutlawZ's Avatar
Default Some updated pics of my project
Well I got the car back from the shop who did my cage and I got done reinstalling the carpeting and finished up about 75% of the gauge installation (I've got 3 more to go where the radio used to be) and I've got to get wolfe racecraft door panels and carpet them.... I pick up my motor on Feb 14. I've got to wire the BS3 and rewire the car to an 8 circuit Pro Street switch panel from Painless.... So still a way to go but I should be ready for some mid spring dyno testing and NA passes.... N20 passes will be dependent on the results we get from the dyno.
Motor is a half filled LT1 383 w/splayed 4 bolt mains, Lunati Pro series crank, Oliver 6" billet rods, JE n2o pistons, 12:1 compression, secondstreetspeed large solid roller (Over .700 lift), Jesel 1.7 ratio shaft rockers, AFR 227 cc comp ported heads, Edelbrock Victor E single plane manifold, Big Stuff 3 standalone. ATI TH400 with 4000 stall ATI converter, Moser 9" 3.89 gears.... 2 stage nitrous kit 1 on plate, 1 direct port. 83lb/hr siemens injectors, etc, etc, etc....
Our target is 850RWHP on both stages of bottle (200/200). Car weighs 3200 with me in it so traction being good should be good for an 8.90 pass or so...
Old Jan 15, 2006 | 06:32 PM
OutlawZ's Avatar
Custom seat mounts (headrest sits on plate that is drilled and tapped, seat was then drilled and mounted to plate using bolt and washer)
Old Jan 15, 2006 | 07:31 PM
METALBEAST's Avatar
Good God Man! That is sick!
Old Jan 15, 2006 | 07:38 PM
OutlawZ's Avatar
thanks man..... i've kept it on the low and haven't said much until I have an 8 second timeslip in my hands..... It's previous best was a 10.40@131 with a budget 355 and a 150 shot....
Old Jan 16, 2006 | 10:56 AM
chris77's Avatar
...ya thats sick man and i thought i was bad with my 396, hell that 383 you got would put the smack down on my car. good job
Old Jan 16, 2006 | 07:04 PM
99.9percenter's Avatar
I want to see pics of the motor.
Old Jan 16, 2006 | 08:44 PM
N20Dave's Avatar
Looks good man. I've got two words for you:
Wheelie bars
Old Jan 17, 2006 | 08:41 AM
Fire67's Avatar
Beautiful! Thats all I can say!
Old Jan 17, 2006 | 12:32 PM
OutlawZ's Avatar
Feb 14th as soon as I see the motor you'll see it too
Wheelie bars
heheheh... yup probably a good idea.... i'm going to attempt it without them since i'll be making NA passes before I even attempt to run the bottle on it. i'll see how bad it is on motor and if it's getting nasty i'll put some on it b4 attempting the jug...
Thanks man...
Old Jan 29, 2006 | 08:15 AM
TimTaylor75's Avatar
I like the guage layout. Provides a good example for those looking to do the same sort of thing.
Old Jan 29, 2006 | 10:26 AM
flyinZ's Avatar
Gauges look badass man!! What are the specs on those wheels? It should be a runner.
Old Jan 29, 2006 | 10:46 AM
LS1SpeedAddict's Avatar
What color is that? looks great might consider getting my dads camaro painted that color.
Old Jan 29, 2006 | 11:42 AM
Hambone 7's Avatar
heh..im sure that isnt street legal in virginia
Old Jan 29, 2006 | 11:54 AM
garth285's Avatar
Hey whats kinda wheels and tires are those?
Old Jan 29, 2006 | 12:57 PM
zigroid's Avatar
wow that looks awesome. the rear stance of that car will make the manliest of men cry home to momma.
hope all turns out well for ya
they look like weld draglites.
Old Jan 29, 2006 | 06:44 PM
TNMuscle's Avatar
that thing looks friggin INSANE lets see some numbers on that motor too.
