Cam Question
Old Jan 15, 2006 | 09:14 PM
White_LightningZ's Avatar
Default Cam Question
Can a cam get you better mpg? Anyone running a cam that got you better fuel economy or know of one for LT1? thanks
Old Jan 15, 2006 | 10:21 PM
dhdenney's Avatar
If you go smaller maybe.
Old Jan 15, 2006 | 10:28 PM
97Formy's Avatar
If you want fuel economy then you chose the wrong car to purchase
Old Jan 16, 2006 | 12:28 AM
travie319's Avatar
look into freeing up airflow and exhaust....that's all I can tell you man!!!
you can also go to a roller rocker...might help with 1-2 mpg...
but I'm guessing at this point!!!
Old Jan 16, 2006 | 03:15 AM
infinitebird's Avatar
Old Jan 16, 2006 | 03:34 AM
Compstall's Avatar
Larger cams are going to take in more air and use more fuel along with it. Buy an electric car.
Old Jan 16, 2006 | 08:14 AM
96capricemgr's Avatar
You can go a little bigger without losing any signifigant milage but you aren't going to gain and it is not the larger cam that allows the same milage it is the supporting mods like headers and intake that offset the lose you should see with a cam.
Old Jan 16, 2006 | 03:36 PM
I have a gm847 so to hell with fuel economy. I just was wondering if anyone ran a cam that got better mpg or about the same as stock. simple question as of yet unanswered.
