Which cam for Ported LT1 heads??
I am currently running a fully ported CNC'd set with a hotcam and would like to make the most out of the heads by going to a bigger cam.
I did a search on this subject and found some cams but not any specs. Please include specs with your cam along with likes and dislikes.
I want to know what everyone is running with their ported heads with possibly dyno numbers backing it up. Specs of the cam grind is what I am looking for.
If your "Stage II" heads, displacement, compression, exhaust, trans, gears, etc. aren't the same as someone elses's, just looking at their cam specs won't really help much. Perhaps the faster guys aren't going to reveal cam specs anyway.
Look man, he asked a simple question. He wanted some dyno numbers from some particular cam grinds using fully ported heads FOR REFERENCE PURPOSES.
Mark
How about this: better flowing heads require less cam than lesser flowing heads to get the same power. Not all "Stage II" of "fully ported" heads flow the same air or with the same quality. With a cam matched to the entire combination of engine and vehicle, you'll see better area under the curve and peak numbers. That doesn't mean the cam needs to be "bigger" as Docspeed suggests, it just has to be better suited to the engine. If you don't have all the relevant data, you are just picking a cam by bra size.
My highly-opinionated $.02
ITS FOR REFERENCE PURPOSES!
Your opinions Flame and Hambone were listened to and this post is in no way targeted at you guys. All of you other guys that posted specs thank you, it was greatly appreciated. Please keep them coming!
Yeah!...maybe your son could teach ya something.....So there.....
P.S. Say hi to Bret for me.......
Cam in my sig....
At least you read it before I got on your "Ignore list".
Old SStroker......
I will say hi, but he might see this before I can.
