Pacesetter Header Questions
Old Jan 19, 2006 | 11:09 AM
ReD95LT1's Avatar
Default Pacesetter Header Questions
Ok here is the deal.
I bought my 95 ta from california, it only has one cat converter. I just received my pacesetter headers with air and egr hook ups. I Will be converting to 2 cat converters. I am having a muffler shop make me my own catted y pipe with cats i provide.
My car should only have 2 o2's right? Are these on the headers themselves or the stock y pipe?
If they are on the stock y pipe, then i will need the muffler shop to weld me some 02 sensor bungs, on the new y pipe and then order WHAT O2 extensions?
Here is a list of extensions....
Part # Product Price My Cart Wish List
125-109009 Oxygen Sensor Extension, 42" Square 4-Pin (Rear Sensor on 1995-1997 dual cat LT1 F-body, Front & Rear on 1998-2002 LS1 F-Body) $25.00 Buy Wish
125-109007 Oxygen Sensor Extension, 24" Square 4-Pin (Rear Sensor on 1995-1997 dual cat LT1 F-body, Front & Rear on 1998-2002 LS1 F-Body) $25.00 Buy Wish
125-109006 Oxygen Sensor Extension, 12" Square 4-Pin (Rear Sensor on 1995-1997 dual cat LT1 F-body, Front & Rear on 1998-2002 LS1 F-Body) $25.00 Buy Wish
125-109011 Oxygen Sensor Extension, 24" Flat 4-Pin (Front Sensor on 1994-1997 F-body, Front & Rear on 1994-1996 Impala SS) $25.00 Buy Wish
125-109002 Oxygen Sensor Extension, 24" Single Wire (Front Sensor on 1993 LT1 F-body) $25.00 Buy Wish
125-104035 O2 Simulator (Single) - 1996-up V8 F-body/Corvette (2 required) - OFF ROAD USE ONLY $44.99 Buy Wish
THANKS!!!
Old Jan 19, 2006 | 12:11 PM
ReD95LT1's Avatar
Alright i finally found out what i need to do, since i have the 95 lt1 obd1, the car wont read anything after the cats, so all i have to do is get the o2 extension flat pin 24"
(part number - 125-109011 at thunder racing)
Old Jan 19, 2006 | 12:58 PM
ExtinctBird's Avatar
You have the correct extensions. I am not clear on your other question. If you received your headers, you should see that the O2 bungs are in the collectors of the headers already.
Old Jan 19, 2006 | 01:19 PM
ReD95LT1's Avatar
yes they are already on the headers, i was just confused as if there were supposed to be O2 sensors after the cat or not, but now i know the only ones i need are on the headers. thanks!
Old Jan 19, 2006 | 01:47 PM
borninatransam's Avatar
where do you live. if you dont have local emissions inspections you could run no cats and then cap the air and egr off and take the air pump off and free up some weight
Old Jan 19, 2006 | 01:52 PM
ReD95LT1's Avatar
I live in arizona and they do smog testing on obd 1 cars.
Old Jan 19, 2006 | 02:43 PM
JL8Jeff's Avatar
12" flat 4 wire extension for driver's side and either the 12" or 24" flat 4 wire extension for the passenger side. 24" extension on the driver's side will leave you with a lot of extra wire to secure and you don't need that.
Old Jan 19, 2006 | 02:52 PM
ReD95LT1's Avatar
so 12" for the drivers side and 24" for the passenger, for sale at thunder racing for 25 any one know of a place cheaper?
Old Jan 19, 2006 | 03:23 PM
StealthFormula's Avatar
check out ws6store one of our sponsors, i think they got em for $15 each but not 100% sure
EDIT: here ya go http://www.ws6project.com/user_stor/...a143b7abbee782
Old Jan 19, 2006 | 03:31 PM
ReD95LT1's Avatar
Those are the square ones, dont i need the flat pins?
Old Jan 19, 2006 | 03:34 PM
o crap i didnt know there were diff kinds, anyone know?????
Old Jan 19, 2006 | 03:50 PM
ReD95LT1's Avatar
yeah im positive that we need the flat pins, thats what thunder racing told me, as well as JL8Jeff
Old Jan 19, 2006 | 06:44 PM
JL8Jeff's Avatar
Summit has the 12" and 24" flat 4 wire extensions for $21.95 each. Search under Caspers Electronics. I posted the part number already but I forget which thread it's in.
Old Jan 19, 2006 | 09:51 PM
ReD95LT1's Avatar
Just to be sure before im about to put the order in this is what i need right? One for the passenger side and one for the driver side? This is the only flat pin i found so could i just get 2 of these and use em both for each side?
Old Jan 20, 2006 | 08:04 AM
JL8Jeff's Avatar
Where are you looking? I already showed the Summit part # for the 12" extension is CEI-109010. Go to their page and search on the part #. It's $21.95
12" Extension
