306 cam And check these valvertrain????
Old Jan 20, 2006 | 08:19 AM
BadCamaro's Avatar
Lightbulb 306 cam And check these valvertrain????
I will upgread my valvetrain and I have stock head
Will these parts #suitable for 306
63-987-16 Comp Cams 1.430" Diameter Double Valve Spring
63-740-16 Comp Cams 10 Degree Steel Retainers for Comp #987 Valvespring.
63-4771-16 Comp Cams Spring Locator Seats for Comp #987 Valvespring
63-613-16 Comp Cams 11/32 10 Degree Machine Steel Locks, set of 16
63-7808-16 Comp Cams Hi-Energy hardened pushrods, 7.200 (OEM Roller - Factory Length)
Old Jan 20, 2006 | 12:12 PM
sssalah's Avatar
Yep, those are the correct numbers. You will have to grind the locators on some spots to clear the valve cover bolt bose on the head. I just cut mine on the lathe.
Old Jan 21, 2006 | 06:33 AM
BadCamaro's Avatar
are u sure its right to buy it?
