97+ gauge cluster swap
Old Jan 22, 2006 | 03:25 PM
Coders11's Avatar
Default 97+ gauge cluster swap
Does anyone know if the 97+ gauge cluster has the same plug as the 93-96 and if the odo will work without any special work
thanks
Old Jan 22, 2006 | 05:05 PM
SLPHawk300's Avatar
thanks
Yes. I have a 1994, and relaced my cluster with one from a 1997. As long as you replace the cluster with another LT1 cluster, you'll be fine. There is even a company that will change the mileage for you, so you have nothing to worry about. If you'd like the name of the company PM me, and i'll let you in.
T
Old Jan 22, 2006 | 07:03 PM
transam5.7lt1's Avatar
Hey, thats interesting, I thought those were different. Sorry, didn't mean to hijack thread, thanks for the help!
Old Jan 22, 2006 | 07:11 PM
BizZzatch350's Avatar
Moderator
Its a direct swap, just on 93s the tach wont work due to the tach filter.
Old Jan 22, 2006 | 09:52 PM
Dragframe's Avatar
so only the 97 will work? Not the 98+??
Old Jan 22, 2006 | 09:53 PM
Rhoop24's Avatar
Correct. Different engine different wiring.
Old Jan 22, 2006 | 10:17 PM
Moderator
Ton of stuff wont work right, another alternative is getting the bezel and after market gauge faces, actually looks really good.
Old Jan 22, 2006 | 11:19 PM
SLPHawk300's Avatar
The 97 will work with all LT1 cars. You cannot use an LS1 cluster due to the fact that alot of the parameters were changed. But all LT1 cars will work with a cluster out of a 1997. Why, do you have different information?
Old Jan 22, 2006 | 11:25 PM
SLPHawk300's Avatar
If you own an LT1, get the 97 cluster. It is identical to the LS1 models in looks, and will work fine for you. I know they're hard to come by, but keep searching i found one on eBay.
Old Mar 29, 2006 | 03:46 PM
SILVERZZ28's Avatar
If you have a 01 LS1 harnes/pcm in a a 95z with 95 gauges is there a way to make the RPM gauge read corretly.
Old Mar 29, 2006 | 03:52 PM
96lt1m6's Avatar
ATTN:93 OWNERS
the cluster swap for you is more involved,94-97 are direct however the 93s require h2o sending unit to be updated,the tach signal is different so it will not function till changed!just a heads up
Old Mar 29, 2006 | 05:10 PM
XxXTransAmXxX's Avatar
SLP glad to know your passing my knowledge on...
Old Mar 29, 2006 | 06:37 PM
Moderator
Was talking about the 98 cluster
Old Mar 30, 2006 | 10:08 AM
SLPHawk300's Avatar
Hey, when you got the knowledge, pass it on right Thanks for all of your help with that, i did find one on ebay for an absolutly ridiculoulsy low price, i felt almost bad taking it for so low. Everything works fine, and that Co. did a great job, just replaced the LCD screen. Thanks, i appreciated that!
Old Mar 30, 2006 | 02:50 PM
Fastbird93's Avatar
Originally Posted by 96lt1m6
ATTN:93 OWNERS
A little extra info: I have two 93's both of which have a 97 cluster. The temp gauges read just fine, no swap there needed as I have verified this using TTS Datamaster.
As for the tach, if you ARE NOT running an aftermarked ignition (such as MSD, Accel, ect) then you need to REMOVE the tach filter, which is a little black box with two white and one black line taped to the wiring harness right next to the coil. Just cut the box off and splice the white wires together. If you ARE running an aftermarket ignition, your tach will function fine. Trust me on that.
Everything else works as advertised with exception to the seat belt light (present for 96 and lower) and the TCS OFF light will remain off if you're a non-TCS car. Simple fix is to use a piece of black cloth and plug the honeycomb holes in the inside of the cluster for those respective lights.
If there's more 93 questions, www.speeddensity.org is your friend.
Old Mar 30, 2006 | 05:04 PM
BlackBirdWs6Zzz's Avatar
I have a 96 but i want the 97 tach......i love the digital instead of the rolling odometer!
