Idle problems
Old Jan 22, 2006 | 03:29 PM
turbotimws6's Avatar
Exclamation Idle problems
about one year ago I had a nitrous back fire. (before I installed Msd.)
Since that time I have had a higher idle(about 1200) I have changed the TB gasket, replaced Iac motor and O-ring. i have checked all my vacum hoses. I am unsure what else might be leaking... I need a little help
Old Jan 22, 2006 | 07:10 PM
transam5.7lt1's Avatar
Is the throttle body spring moving as it should? Check your PCV valves, I had a similar situation, but it resulted on one of the pcv valves staying open... Don't know how it stayed open, I replaced the one in the intake and it solved problem.
Old Jan 22, 2006 | 07:33 PM
Also when I'm coming to a stop(not a panic stop) but semi hard stop the idle shoots to 2100.....
Old Jan 22, 2006 | 08:09 PM
Sounds more like an internal vaccum leak on your brake booster....
Old Jan 22, 2006 | 09:41 PM
FlamingChicken's Avatar
thats what i was thinking as well. def check the booster
Old Jan 23, 2006 | 03:35 AM
whynot's Avatar
one more thing to consider is you intake manifold gaskets. it may of caused a vacume leak by blowing out part of the gasket.
Old Jan 23, 2006 | 08:05 PM
I was thinking that I have a blown intake gasket.
thanks for all yuor help.
Old Jan 23, 2006 | 08:25 PM
dhdenney's Avatar
Should be leaking some oil too if it's intake gasket.
Old Jan 23, 2006 | 08:31 PM
slolt1's Avatar
check the check vale on the brake booster that may be cousing the problem if you let the car sit over night then try to pull the hose from the booster if it does not hve vacum the valve is letting it bled back into the engine
Old Jan 24, 2006 | 02:02 PM
d-marlo1's Avatar
sounds more like an intake gasket, probably blown on the lower side, if so you won't hear a vaccum leak.
Old Jan 24, 2006 | 06:44 PM
whynot's Avatar
that depends on where it blows out, on top it won't, on bottom it may.
Old Jan 24, 2006 | 06:52 PM
I think slolt1 hit it there, might be the check valve on the booster.
Old Jan 29, 2006 | 09:03 PM
checked the valve on the booster, it help vacum for two days. Went back over all of my vacum line( print out by my shop key program.There is no oil leaks nor does it consum any oil. I going to order the intake gaskets and a cam and install kit while the intakes off.
Old Jan 30, 2006 | 09:35 PM
slolt1's Avatar
sorry about that i wish that info would have help you ou when you find out let us know
Old Feb 2, 2006 | 06:11 PM
thanks for your help guys I keep you guys posted
Old Feb 2, 2006 | 08:30 PM
95greenZ's Avatar
Dude, I bet you blew the welds off the intake! (sorry couln't resist)
Have you checked the TPS maybe it was a coincedence that it started after the backfire. Just giving you other ideas.
