Killed at wot
Old Jan 28, 2006 | 12:48 AM
xtinctbird's Avatar
Default Killed at wot
I bought this car for real cheap but it ran great up until WOT. It is a full bolt on car with long tubes and a borla catback. It also has a 150 shot dry kit(nos) came with the car. Problem is after replacing plugs, wires and the opti, it still is sluggish as hell when you really get into the throttle, and when you hit wot it just about dies. If you let off a litlle bit it will pull out of the stumble and pull well. Why does it fall apart at wot?
Old Jan 28, 2006 | 01:00 AM
buffman's Avatar
new opti??? or just new cap and rotor? How about the Ignition Control Module, or the Coil itself, or the coolant temperature sending unit in the WP
Old Jan 28, 2006 | 01:09 AM
xtinctbird's Avatar
New opti. new coil, new wires, new water pump. Thats about it, it pulls hard right up to wot the just completly falls apart
Old Jan 28, 2006 | 01:12 AM
xtinctbird's Avatar
but I did not replace the icm
Old Jan 28, 2006 | 03:36 AM
MattZ28's Avatar
Sounds like lack of fuel to me.
Go get a gauge from Discount Auto or whatever, and see if the fuel pressure drops when you get on it.
Old Jan 28, 2006 | 03:39 AM
TwoFast4Lv's Avatar
Like Matt said lack of fuel or bad Program
Old Jan 28, 2006 | 07:52 AM
xtinctbird's Avatar
thanks guys, going to go get a fuel pressure gage this morning
