gears
Old Jan 28, 2006 | 07:47 PM
slolt1's Avatar
Default help me pick the right gears for the spray
i am about to get my car finished to the point that i can spray again and i am now running 4.11 with the 93 6 speed trans what gear would you suggest
Old Jan 28, 2006 | 07:59 PM
blind527's Avatar
4.11's are fine.
Old Jan 28, 2006 | 08:18 PM
transam5.7lt1's Avatar
I'll say 3.73, I once drove a 94 m6 camaro with 4.10 and gear shifting seemed too short. I mean shifting 1st to 2nd, and 2nd to 3rd.
Old Jan 28, 2006 | 08:48 PM
Jditlfm's Avatar
Have to remember that the 93 trannys ahve diffrent gear ratios for the first couple of gears. and hes spraying so the has to have the little cushion for a gear. Another thing you should take into account is the overall tire height. Their are gear calculators that will tell you what final drive ratios are needed for the 1/4 based on wheel size and so on. Just some things i thought you should know.
Old Jan 28, 2006 | 09:53 PM
slolt1's Avatar
yeah i am shifting real quick now i am turning 4th gear in the 1/8 spray is realy going to be pushing me i think i am running 26.10.5.15 so any body wanna throw some sugestions at me i will be gratefull thanks brad
Old Jan 28, 2006 | 10:17 PM
rkinney's Avatar
I have a 93 with the m29 t56 and I have 3.73's. It's about the same as the
94- present t56 running 4.10's 1st-3rd, and 5th and 6th are deeper in the m29 as well. Running a 4.10 in the m29 is like 4.56 in 94-up. I used to run 3.42's, but wanted a little more gear so moved it up a bit. Even with 3.73's with m29 you might still have to shift to fourth for the 1/8 mile. I like my 3.73's though.
Old Jan 28, 2006 | 10:21 PM
slolt1's Avatar
thanks i have a narowed ford 9 inch and i m kinda debating on either the 3.70 or the 3.90 before i put the rear in i had 3.73 and loved it but know with the 4.10 i have got a bad traction problem and i am looking at nothing but shift light i kinda belive if i raise the gear i will be a litle quickeer
