Clearance issues with header studs?
Old Jan 30, 2006 | 03:08 PM
SiCk PuPpY's Avatar
Default Clearance issues with header studs?
I'm considering using the ARP header studs with my Jet-Hot long tubes. Are there any clearance or installation/removal issues to be concerened about?
John
Old Jan 30, 2006 | 07:31 PM
FlamingChicken's Avatar
Just basing my opinion on my header install with bolts, i would think it would be a pain in the *** to do if the engine is in the car. drop the engine and it would be no problem. maybe someone else on the board has actually used studs.
Old Jan 30, 2006 | 07:37 PM
SiCk PuPpY's Avatar
The motor is out of the car for "upgrades". I was curious if they would cause problems if I needed to remove the headers in the future (with the motor in the car).
Old Jan 30, 2006 | 08:24 PM
blind527's Avatar
The ARP header bolts are amazing. They are only 5/16" heads instead of the 10mm, MUCh smaller, and NO problems. You can get a wrench in there with no problem. They wouldn't cause problems at all, and it's not hard while the engine is in the car.
Old Jan 30, 2006 | 11:08 PM
rebersole2's Avatar
I would think that the studs would be a pain. There is just not enough room to maneuver headers in and out, off and on in newer F-Body. There are good aftermarket header bolts out there, I think you may be playing with fire, and with headers, you migt get burned.
Old Jan 31, 2006 | 10:36 AM
SiCk PuPpY's Avatar
Thanks for the inputs; i'll use the ARP bolts instead of the studs.
