What Numbers amI looking at with this setup 383
AFR LT4 195 CC 64cc chambers with rev kit
Comp Cams Extreme Energy 510/520 lift 230/236 @50 Lobe 112
LT4 Intake
Bosch 30LB injectors
Walbro 255 Fuel Pump
LT4 Intake
Pro Magnum 1.6 Rockers
Aeromotive GM LT-1 Fuel Pressure Regulators
ATI Fluidampr LT1 Harmonic Damper
BMR upper & Lower A Arms
BMR K-member
BMR Lower control arms
Sphon Adjustable Torque Arm
QA1 adjustable Front and rear shocks
QA1 300lbs Front springs
NX Nitrous Express up to 250 shot ('I'll probably do )
Hooker LT headers with Dynomax 24" Bullet
3.73 Motive Gears
Zexel Torsen heavy duty Posi
Moser Heavy Duty axels
Still missing some odds and ends.
Push rods, TB, timeing chain, Optispark, Oil pan and other stuff
what pistons do you have? flat tops? dished? with 64 cc heads on a 383 with flat top pistons you should have near stock compression.
if you're gonna spray get bigger injectors. I have 37s and I don't plan on any forced induction.
im sure the stock rear end will hold for awhile, well maybe till you sprayed it with some good tires. lol
also i would wait till you get the heads flowed, then have someone make a custom cam for it.
