Head Gasket
Old Feb 19, 2006 | 01:03 PM
White_LightningZ's Avatar
Default Head Gasket
What is the thinniest head gasket that is recommended for stock unmilled heads and stock engine?
I was thinking of going with a Mr. Gasket Ultra-Seal (.026" thick compared to stock .050" thick)
How much will this raise my compression (what would the ratio be)? I will run 93 all the time but I do not want to worry about pinging or engine damage/premature wear etc.
Will my fuel mpg improve or get worse? If so by how much?
This is a daily driver so I want to do it right but would like a little boost as long as it is safe.
With a stock engine & cam will raising my compression actually hurt performance?
stock block 97z28. Will get a pcm tune after too. What should I tune to take advantage of the extra compression? How do tuners tune (like madz28 does) for premium gas and acheive a 5-7 rwhp gain? I have tunercat btw.
Old Feb 20, 2006 | 07:08 PM
come on guys? Maybe I should post this in the LS1 section lol.
Old Feb 20, 2006 | 07:54 PM
96capricemgr's Avatar
I have not measuresd a stock shortblock so I can't really say on compression but on the tuning it is usually leaner fueling and some work with the timing.
