Adj fuel press reg
Originally Posted by blkchevyz
you are correct that the o2 are ignored, but if the blms are way lean when it goes to pe mode its going to add a percentage of fuel to the table to keep itself safe.
I know O2's aren't the best way to monitor A/F ratio, but does anyone know O2s voltages for APPROXIMATELY 14.7 cruising? I don't have a wideband and will not buy one so I was always wondering how good my highway tuning was.
Originally Posted by smoknta
But if they are programmed out like he says they are, the BLM's should be locked a 128.
Under most normal circumstances, fuel trims will be locked in PE mode and will not effect fuel management.
Originally Posted by HBHRacing
There is no set voltage. During idle and part throttle the 02's will constantly be switching above and below bias voltage (450 Mv) trying to maintain your 14.7 ratio. your long term fuel trims will tell more about your hwy performance then 02 voltage ever will.
