recommended spark plugs?
also i got taylor 8mm wires which is recommended..
good luck
If you want a good, high quality plug that will last around 25K miles before it needs changing, get the NGK TR55.
If you want a good, high quality plug that will last around 50K miles before it needs changing, get the stock AC delco plugs.
There is NO performance difference between a stock AC Delco plug and the NGKs. The only difference is in your head, created by careful marketing.
