best LT1/LT4 heads
Same thing at the track. And, yes guys do that at the track.
Btw, flow benches vary so much, seeing a flow sheet means nothing at all.
Flow numbers are only useful compared to the same physical bench, using the same test pressure.
BrandonB
If you are going to get a guy to redo the whole port, put their valve job on it, suggest different springs/valves, etc....you might as well send them a pro port and let them do it from scratch with an AFR/Trick Flow casting.
That would be great if their turn around time is realistic. It wasn't too long ago where they were ignoring phone calls and e-mails of those who were inquiring about LT1 stuff. I do believe someone here did get ahold of them and they said LT1 **** was the lowest of their priorities, at least at that specific time (a few years ago). Another shame is Craig with GTP, whose heads were very high caliber, but once he got too popular his customer service went to ****. I'd take his heads any day of the week even on a Friday over LE.
