LT1 vs. LS1
Old Feb 27, 2006 | 01:12 AM
flyin red TA's Avatar
Yep...another Spuds driveby owning.
Old Feb 27, 2006 | 06:59 AM
Sgt. Spuds's Avatar
Shirley Temple Drinker
What ever that means ^
I forgot all about the mains.. Good point.
But why do so many guys go to Iron blocks when running lots of power? I haven't read into FI a lot but it seems that I've heard a lot about them going to Iron blocks?
Old Feb 27, 2006 | 09:44 AM
Camaroz's Avatar
Originally Posted by Vendetta
It's not an issue at all. It's Spuds spreading misinformation.
And when this thread gets out of hand...... IBTL!
Old Feb 27, 2006 | 10:59 AM
Chris 96 WS6's Avatar
Speaking as an LT1 owner, there's no excuse at this point if your budget is at or near $10K or above NOT to buy an LS1 car. The LT1's were great for their day but its like trying to swim upstream when its so much easier to make big power with the LS1. Hell we're having this exact debate at LS1LT1.com right now with a newb that is quoting factory rated HP and saying the LS1 is the LT1's "little brother", LOL Here's the thread.... http://www.ls1lt1.com/forum/showthread.php?t=3032
Old Feb 27, 2006 | 12:34 PM
It means you said something completely wrong and got called out on it. Just because a block is iron does not mean that it's automatically stronger than an aluminum block. There's a lot more to it than just the material used.
Old Feb 28, 2006 | 07:20 AM
Justin00SS's Avatar
Originally Posted by 02Vortech
i know that the ls1 makes more power but i am looking to sell the blazer and spray my next car- i have found some low mileage 4.6L mustang GT's but i found out that the stock motor can only handle 400hp
i would like an ls1 but they are out of my price range- so i got some questions about the lt1
1.)How much horsepower can a stock LT1 block handle?
2.)What is there stock 1/4 mile time
3.)Do they have a 4l60e if its an a/t what do they have if its a m/t
4.)Can they handle some abuse?
5.)Are they easily upgraded
There are guys running ~900hp on stock bottom end with the 4.6L block.
Old Feb 28, 2006 | 08:20 AM
treyZ28's Avatar
unless you are going sub 9 second times- dont worry about the block.
Old Feb 28, 2006 | 10:05 AM
BlueSix's Avatar
Um, no. Sorry, but no stock bottom end 2v 4.6 will handle that power.
Old Feb 28, 2006 | 10:11 AM
Is it just me or do these LS1 v. LT1 threads have like 9 lives? They just won't die.
Old Feb 28, 2006 | 10:18 AM
treyZ28's Avatar
not for long anyway.
Old Feb 28, 2006 | 11:42 AM
Ling_650vette's Avatar
Because look at what most of these guys are doing with those iron vs aluminum blocks. They're getting iron blocks for cheaper more than anything else, and then its just as easy to bore out and make a larger engine. The strength is a moot point being its proven that LS1s can handle some abuse.
But to 90-95% of the street driving public, its a moot point. The block strength wont ever be noticed. Its more of a cost factor than anything else in my eyes.
Old Feb 28, 2006 | 01:07 PM
  #32
MillaTK's Avatar
Yeah...Hell, look at the 302W blocks from Ford... Iron blocks, and people are splitting them in half with 400hp
Old Feb 28, 2006 | 03:56 PM
  #33
Justin00SS's Avatar
Did I say they last long? I only said it was done successfully.
Old Feb 28, 2006 | 09:18 PM
  #34
BlueSix's Avatar
OK, you show me a 2v 4.6 that's putting 750hp+ to the ground with the stock bottom end then i'll believe you. Until then,
Old Feb 28, 2006 | 09:42 PM
  #35
treyZ28's Avatar
uhh... most racecars DONT run cast iron blocks. C6R? S7? Enzo? Porsche GT? F1? M3? M5?
Not unless its for budget reasons or they are making INSANE power. Maybe something that needs to support the pull of a blower that takes 400hp to turn alone(top fuel).
Actually, supercharged cars are the only cast-iron blocks I can think of except maybe the mercedes V12?
What racecars do you know of that run cast iron blocks that aren't required to by the rulebook?
Old Feb 28, 2006 | 10:05 PM
  #36
angel71rs's Avatar
my price range is 13k thats it
A lot of good deals on the boards under 13k, e.g.:
http://web.camaross.com/forums/showt...highlight=2000
Old Feb 28, 2006 | 10:23 PM
  #37
I had a friend that did 650...
...twice. It cracked the block on the dyno.
Old Mar 1, 2006 | 02:31 AM
  #38
treyZ28's Avatar
I dont think thats putting 650 to the ground... thats more breaking your engine with 650hp
Old Mar 1, 2006 | 06:55 AM
  #39
00SLPSS's Avatar
my DD before this was a blown 2v. I made a little over 400 to the tires, then had it de-tuned to 390. I'd say for average thats about as much as you are going to make safely stock bottom end w/o ported heads/cams/intake.
Old Mar 1, 2006 | 09:29 AM
  #40
BlueSix's Avatar
Like i said, show me one that is putting 750+ to the ground (stock bottom end) and then i'll believe you. So far no one's shut me up.
