LT1 A4 cam recomendations
Old Feb 26, 2006 | 08:00 PM
aboatguy's Avatar
Default LT1 A4 cam recomendations
My heads are being ported and it's time for me to ask about CAM recommendations.
My car's published shipping weight is 3360, so make it 3600lbs on the street.
I have:
58mm TB
Electric H20 pump
7/16 1.6 ratio NSA Comp Pro Mag rocker arms
1 3/4" primary Long tubes
3" collectors and 3" high flow cats
Smallest size pipe in my exhaust is 2 1/2" most of it is 2 3/4"
2800 stall converter with lockup
4L60E
3.45 rear end gears
285/40/17 tires
What are you running and if you could do it over again what cam would you run?
Old Feb 26, 2006 | 08:25 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Was running a hot cam in a 383, now i will be running a custom Bret Bauer cam. Since you have the desired rocker/stud setup I would check out what he has. Also knowing what your flow specs will help you figure out your choice on cam.
Old Mar 6, 2006 | 08:04 AM
aboatguy's Avatar
Approximate flow numbers
Lift.... .100 .200 .300 .400 .500 .600 .700
Intake.. 70 146 202 244 269 275 273
Exhaust 60 116 153 172 187 193 196
Old Mar 6, 2006 | 09:25 AM
Chris 96 WS6's Avatar
On the stock heads I really like the XE 224/230, but I like a touch more driveability than most.
