Is this true???
Old Mar 1, 2006 | 06:47 PM
State69champ's Avatar
Default Is this true???
I have a 95 Z and someone told me that I have the same bolt pattern at a c5 vette.. I have seen a pic of front sepention of a vette and it looks almost the same i guess... so if thats the case can i get c5 breaks?? b/c my breaks are weak sause.
Old Mar 1, 2006 | 08:17 PM
GSDZ28's Avatar
ok, i guess your asking if brakes off a vette would fit your car, yeah they probably would, but i don't how much better they would be than your stock one, maybe a little.
IMO you probaly better off just getting some slotted rotors and nice brake pads that are made specifically for your Z28.
Old Mar 1, 2006 | 08:21 PM
ec_nova's Avatar
they sell c5 brake kits, but you'll need 17" wheels to fit them. Some 17's wont fit, but gm 90-something and up will work.
http://www.kore3.com/
cheapest site i've found. better than any big brake kit because it's all OEM parts. parts that were tested over and over, and have to meet safety regulations unlike kits. plus, pads/rotor/calipers are a dime a dozen.
Old Mar 1, 2006 | 08:25 PM
omaha stylee's Avatar
switch to ls1 brakes they have dual piston calipers and bigger rotors....... plus they will fit 16" wheels and they are relativey cheap used....... I just swiched mine over and am very happy with them..... they are also drilled and slotted
Old Mar 1, 2006 | 08:31 PM
slick1851's Avatar
Yes man were have you been? lol under a rock?
Old Mar 1, 2006 | 08:52 PM
well... if i go to ls1 breaks i have to change the whole front setup... and i dont know how much that would cost... but i would do that if it was cheaper...
Old Mar 1, 2006 | 11:27 PM
Speed Density's Avatar
hashtagBMW
State, if you plan on running racing wheels, ex. Prostars, Convo, D10s your going to have to grind the **** out of LS1 brakes, its gona be a **** load more work than just keepin the LT1 setup and using slotted rotors.
Old Mar 1, 2006 | 11:45 PM
someone scared of a little elbow grease???
grinding the breaks down really isn't that bad..... and thats only if you are going to run a big slick on the back......
Old Mar 1, 2006 | 11:53 PM
Vendetta's Avatar
No need to be an *******, the guy asked an honest question. Post something useful or GTFO. Kthx.
It'd be worth it. LT1 brakes are awful.
Old Mar 2, 2006 | 12:01 AM
hashtagBMW
Scurd nope. I actually have Front and Back Prostars coming, so im getting ready to do some grinding myself.
Old Mar 2, 2006 | 01:42 AM
thata boy
Old Mar 2, 2006 | 01:43 AM
its much cheaper i bet you could find the whole set up used for under 4 bills on here....... look into it.....it will be worth ur while
Old Mar 2, 2006 | 01:50 AM
slick1851's Avatar
Well since there is somthing called SEARCH and this was a very very talked about topic there is a tone of info on it.
Sorry but search then ask a qeustion, its like those what would this catback sound thread that used to pop up every hour!
Old Mar 2, 2006 | 02:17 AM
hashtagBMW
Cmon man, its a forum the guy asked a question. Yes there is search but you dont have to be a hard *** about it. I for one always forget to search and then i get bitched at.
Old Mar 2, 2006 | 05:15 AM
d-marlo1's Avatar
I got my ls1 brakes for 100.00 at a local junk yard, changed them out in 45 min. and now she will stand on its nose.
