fuel regulater/injecters????
Old Mar 2, 2006 | 03:03 PM
silverlt1ss's Avatar
Default fuel regulater/injecters????
do adj.fuel pressure regulators help(worth it) on a bolt lt1???? would injecters be helpful also???? all the mods are in my sig. i just heard that alot of lt1's run lean and since mine is modded a little, i wanted to know if bigger injecters and a adj.fuel regulater was nessesary??????? if so are they hard to adjust or do i need a dyno??
Old Mar 2, 2006 | 04:39 PM
ttt...
Old Mar 2, 2006 | 05:29 PM
2000GTP's Avatar
Aftermarket injectors and fpr will do nothing for you. Only do injectors if you step up to a heads/cam package or slap on a supercharger. A mail order tune can adjust your A/F ratio to gain some extra power however.
Old Mar 2, 2006 | 08:05 PM
savethelinoleum's Avatar
Everything here says that you shouldn't go above stock injectors until you've done heads/cam as said above.. just doing bolt ons does not require more than the stock injectors will provide. Just do a search for "injectors" in the LT1 forum, it's a question that gets asked all the time. IF you decide to upgrade the injectors now, you'll definately have to get a tune. They say your injectors should be 80-85% load.
