m6-th350
Old Mar 6, 2006 | 05:40 PM
slolt1's Avatar
Default m6-th350
just wanting to see how many people has done this and if you picked up any time on the track or if it slowed you down i am considering it but i just dont want to slow the car down any also wanting to now if i can use the stock cross member and if i need the 6 inch tail housing or the 9 inch one any help will be real nice thanks
Old Mar 6, 2006 | 07:57 PM
slolt1's Avatar
incase you dont know what i am talking about m6 6speed trans to a turbo 350 auto trans some body has to have done this a now whether or not they picked up a tenth or 2
Old Mar 6, 2006 | 08:35 PM
streetrod93's Avatar
if you do it, go with the 9 inch tail shaft
i'm actually planning on doing it once i get my new daily driver...if nothing else, the automatic makes for a much more concistant car....and a whole lot easier to get out of the hole.
Old Mar 6, 2006 | 08:52 PM
slolt1's Avatar
yeah my problem know is spinning,hoping; and the best is the stage 3 has started slipin and i cant pay 600.00 a for a few street miles and around 10 passes
Old Mar 7, 2006 | 06:37 PM
foggedz's Avatar
I swaped out the M6 for a th350. The car picked up so much time that I actually run faster on motor with the th350 than I ever did on spray with the M6. I did other small things along with the trans swap, but everything the same other than the trans I would say the car would pick up 7-8 tenths.
Old Mar 7, 2006 | 07:38 PM
slick1851's Avatar
Is your trans good, Im thinking about doing a 6speed swap so if your doing a auto you might have a buyer for a 6speed conversion.
I only ask is the trans perfect? Im on a real budget and cant afford to get fucked over...
Old Mar 7, 2006 | 09:54 PM
slolt1's Avatar
sent you a pm slick1851
Old Mar 7, 2006 | 10:24 PM
Hambone 7's Avatar
I went from the 4L60 to a th350 and I miss the overdrive ALOT. I wouldnt go from an m6 to 3-speed. You might see a gain with a stall converter but it will be more from the consistency of the auto trans as compared to the driver error/quickness factor of the manual. Drive the m6 around in 4th gear on the freeway, you'll see what I mean about no crusing. I bought an adapter for my TCI trans that let me keep the 4l60 tailshaft, speedo sensor, and TQ arm mount.
