Heating problem
Old Mar 7, 2006 | 04:01 PM
BlackBirdWs6Zzz's Avatar
Default Heating problem
So once i get my radiator, hopefully i'll have NO LEAK and FULL PRESSURE.
Once i run it for a while and i'm driving and i stop and turn off the car, then it starts spraying out of the leak and it shoots it on the engine and it smokes.......but if a leave it and let it warm up it'll go up past 210, haven't seen it gone farther yet (haven't tested It) but once i start driving then it's cool and starts cooling down..........any suggestions? Other then the leak. Could it be my thermo.
Where IS the thermostat?
Old Mar 7, 2006 | 04:20 PM
2fast97Z's Avatar
if your really asking where the thermostat is.........pull off your intake tube after the throttle body and un pressure the coolant system etc. and then start taking the coolant tube off of the wierd looking metal elbow..it will leak coolant still...then undo the two screws that hold the elbow in and then pull that off..the thermostat is right under that..hope that helps
Old Mar 7, 2006 | 04:34 PM
thats awesome thanks. ANy other suggestions on my problem?
Old Mar 7, 2006 | 05:05 PM
anybody have a visual?? I want to know what the "weird looking metal elbow is" Is he talking about the water pump? haha. Just wondering. thanks
Old Mar 8, 2006 | 12:25 PM
beast69camaro's Avatar
yeah man, the "funny little elbow" is on top of the water pump, and the thermostat is under that (in the water pump). hope that helps.
Old Mar 8, 2006 | 12:31 PM
the visual you requested.....just pulled from google (first time posting a pic, sorry if it doesn't work)
[IMG]tstat.jpg[/IMG]
Old Mar 8, 2006 | 12:32 PM
the visual you requested.....just pulled from google (sorry don't feel like figuring out how to post pics)
http://shbox.com/1/tstat.jpg
and another for good measure:
http://69.20.110.81/images/products/...s/12527739.jpg
Old Mar 8, 2006 | 03:19 PM
that weird elbow thing is a LT1 Water Coolant Thermostat Housing. hahaha. just so you know Thanks for the visual aids. In case i have to do that i'll know where it is. Plus the thermostat isn't expensive anyways!
I think it just maybe my radiator so that should be coming in soon and i'll be putting it in this weekend! yay!
