2 bolt or 4 bolt
Old Mar 8, 2006 | 10:11 PM
sscamaro96's Avatar
Default 2 bolt or 4 bolt
i have never torn into an LT1 and i wanted to know if my 1996 SS has 2 bolt mains or 4 bolt, im pretty sure its 2 bolt but i just wanted to make sure, and i also wanted to know how much power the 2 bolts can handle
Old Mar 8, 2006 | 10:15 PM
Ls1Bait's Avatar
Your car is a 2 bolt. The vettes have 4 bolts. The two bolt can hold alot of power 500-600 hp no problem. Its in the stock internals is were you may see problems if you get to those numbers.
Old Mar 8, 2006 | 10:23 PM
firetird's Avatar
horsepower isnt the only thing you need to worry about with a 2 bolt block, rpm is just as important. You can make 550 whp but if you turn to 8000 rpm then you will have problems with the two bolt caps. On the other hand, you can make 700 whp only spinning to 5500 rpm's and i would say a studded two bolt would work just fine. I know most people are going to say that you will need a 4 bolt conversion but i think most people just do that because someone tells them they should.
Old Mar 8, 2006 | 10:26 PM
gator's 99TA's Avatar
we have gone 9.82 @ 140 on drag radials at a gross 3700 lbs raceweight on a 2 bolt main lt1 here.
Old Mar 8, 2006 | 10:33 PM
firetird's Avatar
are the caps studded? how many rpm's do you turn?
Old Mar 9, 2006 | 07:12 AM
Camaroholic's Avatar
Warranty replacement motors (aluminum headed, anyway) were 4 bolt.
At least mine was. Not that it could protect against a self destructing CompCams timing gear setup...
Old Mar 9, 2006 | 07:14 PM
96capricemgr's Avatar
This is the first 2bolt vs. 4 bolt thread where everyone has replied intelligently .
Listen to these guys.
A lot of truth here
Most of those who have actually pushed the 2 bolts or just studded them have had exellent results.
Old Mar 9, 2006 | 08:11 PM
dhdenney's Avatar
I've never heard of anyone breaking a main. BTW, I have 2 bolt mains.
Old Mar 9, 2006 | 08:28 PM
borninatransam's Avatar
same here i dont think ive ever heard of anyone breaking the mains anyway. most of the people ive heard of doing it are ones who that are going to do serious full out drag cars.
slagger's Avatar
my builder suggest keep my 2-bolt mains put studs and invest in alittle better rods.
not saying the LT1 rods are bad but, the price you pay to take them off the old pistons, polish the beams & shot pen,recondition,balance them,new ARP bolts. you'll spend about the same if you buy rods that already have all that, and stronger.
Old Mar 9, 2006 | 08:46 PM
I would agree with that.
Old Mar 10, 2006 | 07:41 AM
firebird6786's Avatar
change the rods there bad just like the ls1 stock rods and up grade the the rod bolts. i think you people are CRAZY running that much power and money in your motor on a 2bolt, have it splayed to a 4bolt just to be safe.
Old Mar 10, 2006 | 08:56 AM
CatchinZs's Avatar
I had mine converted to a 4 bolt just for piece of mind.
When your planning your build you really need to take into consideration your future plans....my plans were heavy nitrous use with the addition of a second power adder in the future.
For me it was worth the extra money to be ready for anything I throw at it.
If I wasn't going the power adder route I would say that a 2 bolt would work just fine for a very heathly setup as many have mentioned before.
Old Mar 10, 2006 | 09:31 AM
96SCTA's Avatar
I went with a 4 bolt after 2 years of running 10lbs of boost on a studded 2 bolt. The 2 caps were showing signs of chaffing where they were lifting and comming back against the block.
Old Mar 10, 2006 | 09:57 AM
A-man930's Avatar
Definately listen to this guy. Are you planning on running crazy boost or nitros, or spinning 8 grand? If so, you should probly spend the extra bucks and get a splayed 4-bolt. Not claiming to be an expert here, but it makes sense if you want/need some added insurance.
Old Mar 10, 2006 | 10:31 AM
MrBill97396's Avatar
Ask Big Rick in his old street car days his 383 with nitrous was a 2 bolt
Old Mar 10, 2006 | 01:15 PM
CatchinZs's Avatar
There have been a lot of very knowledgeable people run both setups.
Big Rick is definitely an example of a person who can setup a racecar.
For me...I am just more at piece with the fact that I had mine converted to a 4 bolt.
I spoke with numerous engine builders before I went Eric Koenig (Racer8077...I think is his username here) based out of HPE's shop.
All gave me the same basic idea that the level that I planned to be at would not require a 4 bolt setup but it was advisable for longevity...remember these guys all want us to be happy with our purchase and get years of use out of it.
Old Mar 10, 2006 | 01:44 PM
SStrokerAce's Avatar
If you want to put more than 450rwhp thru the block you should put a 4 bolt cap on in a street motor. In high RPM race motors, or motors where the majority of the time they are actually at WOT that HP level comes down. Around here we have 430hp (flywheel) circle track motors that would be dead if they were two bolts. That's equal to 370rwhp.
Plain and simple is it's gonna cost you more to fix the mess the motor makes when the 2 bolts give up the ghost than it's gonna cost to put the 4 bolts on.
Bret
Old Mar 15, 2006 | 11:18 PM
racer7088's Avatar
Arrow
Bret
A remarkable happening but I totally agree with Bret here. I have seen cap walk after only a few dyno pulls even recently at 520+ hp on the 2-bolts. There's a reason so many people run the splayed caps. Usually they've already been through the 2-bolt OEM route once before.
I am surprised though at the total abuse SOME blocks with the 2-bolts still on them have taken but they will cap walk like crazy and they will break if pushed hard enough. We've taken the 4 bolt OEM deals off too in pieces quite a few times after people see oil pressure is lost.
