what is the highest hp for stock heads?
When I first built my Camaro I built a cam only L99. It ran 7.85 at 3300 lbs. I then built an LT1 that went 6.76 with .030 factory pistons and stock rods. The last motor in the car had all of the best pieces in the bottom end and ran 6.61.
There were also a lot of other LT1's and LT4's in both cars, but these were the highlights.
The Camaro also sixty foots in the 1.3's on 9" tires. I bet that's not possible either?
No dyno sheets, but a bunch of IHRA National Records over the years.
Daren Poole-Adams
IHRA 9043
something us stock pcm guys can't do
The first thing I did on my Firebird was toss the factory PCM. Even with the bone stock motor. An aftermarket computer is the only way to go. I change gears, transmissions, cams, headers, etc. so often that it would be a nightmare to work with the factory PCM. Not to mention that you can rev over 7000 with an aftermarket PCM and you can dump all of the emission controls, etc.
Daren
2nd off why put the time in on something like this. why would u want to make max horsepower on stock lift. your just asking for something to break.
oh yeah i made 50hp gains from a coldair intake and a catback
http://www.mofbody.com/blkchevyz/web.../lt1launch.JPG
what they can do with stock ci, and stock heads are amazine.
Here's the Camaro at the Kinston IHRA race last year.
http://www.ihra.com/gallery/main.php..._itemId=116038
it was from the chaftsmen nationals, probably 2 or 3 years ago
http://www.mofbody.com/blkchevyz/web...ic/fastlt1.jpg
they all just think since they cant do it, it cant be done
And to the person who asked why would you want to make max power on stock lift BECAUSE THOSE ARE THE RULES TO RUN IN STOCK ELIMINATOR..... read the post before you reply man...
I only reply to threads like this because I think that a lot of guys are of the opinion that the factory parts are not very good.
I race Stock Eliminator because it has the most restrictive rules in all of drag racing. I was gung ho to build an LT4 for the LS1 Tech Series. I liked the fact that they had a fixed set of rules. It was a shame that they cancelled. I think that an LT4 would have been able to run with the LS1's.
That other Camaro is not my car. It's amazing how many of them are running IHRA/NHRA.
Good class racing sites are;
www.classracer.com
www.superstockforum.com
Take Care,
Daren
The trick to the motor is the blueprint. Everything is right at the edge of the NHRA specs. That means .060 over pistons and about .013 extra stroke (.070 and .015 are the max allowed). Rings play a major role. So does oil control. I run a truck pan with four quarts of Mobile one. Most of the oil drain backs are plugged to stop oil hitting the cam. The hydraulic lifters are modified to allow more rpm. The trick to getting the heads right is the valve job. A three angle job is allowed, but it can't exceed 1/4" top to bottom. Aftermarket 1.94/1.50 valves are allowed (no titanium). The combustion chambers are all matched to the same volume. The block is decked to .015 in the hole and a factory head gasket is used. Everything is balanced and an ATI damper is used. The alternator is the only accessory required. A good assembled short block takes 15 lbs or less to rotate! Really the motors are good bit away from stock. I use the best parts that I can afford and the best engine shop (Warren Racing).
Frank,
I think we met at Thunder a couple of years ago?
Daren
You dont do anything with a stock LT1. its a waste of time and money. if i had a LS1 and a tight budget i would definitely consider it. You just get way better results with a stock LS1. This is why the LT1 has a bad rep with LS1.
