Idle trouble.
Old Mar 13, 2006 | 11:09 AM
TurboZ28's Avatar
Default Idle trouble.
Car is a 97 LT1. Starting on Sat., my car started having trouble holding idle. While driving, a light will turn red, take it out of gear and and start braking, it dies completely. If I start it and it's sitting still then it'll hold a REAL choppy idle at about 600rpm's. Before this started, it would idle real high when the car was rolling, but would go down to about 1000rpm's when I came to a complete stop. Any ideas on which sensor is the culprit?
Old Mar 13, 2006 | 02:13 PM
TurboZ28's Avatar
Somebody's got to know this.
Right?
Old Mar 13, 2006 | 02:19 PM
Camaroholic's Avatar
You do anything to the car recently? Fiddle with anything?
I ran in to something similar once. Had a 93 Z28 w/ 383 that wouldn't idle. No matter what I did ECM wise, it couldn't hold it. Everything looked OK on the scan tool. Looked OK under the hood... Until I pulled the throttle body off. Noticed that 1 wire on the IAC motor was very lightly broken, but the insulation was holding it in place. Whipped out the strippers and the soldering iron... Bam. Idled great.
Old Mar 13, 2006 | 08:23 PM
transam5.7lt1's Avatar
Bad spark plug wires? Vaccumm leak?
Old Mar 14, 2006 | 10:13 AM
TurboZ28's Avatar
lol OMG thanks man. I just remembered I had to ghetto mend a vacuum line with duct tape a while back. God im an idiot Take a look as soon as I get home and get back with yall.
Old Mar 14, 2006 | 04:26 PM
Originally Posted by TurboZ28
ghetto mend ... with duct tape
There's your sign...
Old Mar 15, 2006 | 04:09 PM
Black1997T/A's Avatar
If its not thst, its probably is the IAC valve. Mine went bad.
